33 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Backup files
Tue, Oct 14, 2008 at 11:29:22 AM | Backup files
Shaunab
I have just enabled worksharing on a project and since then my backup folders contain no RVT files.  It created a new file folder for backups (projectname_backups) and the only thing in the folder are DAT files, and RWS files.  Under "file/backups" on the pulldown there are no files showing. This is happening with all three local files and the central file.
 There are files in the "C:program files/revit 2009/journal" folder but they are before worksharing was enabled.
Tue, Oct 14, 2008 at 2:49:48 PM | Backup files
robinballew
robinballew Avatar
3 Stars: 4 Votes
The central file will keep all the "Back-up" Files. Go to File:Backups and find the Central File folder with _backup. It will list all the saved version and who saved it. You can now "Roll Back" to what ever you want.
BallewDesigns.com
Tue, Oct 14, 2008 at 2:55:20 PM | Backup files
Shaunab
There are no "_backup files" to roll back to.  When I go to "file/backups" I can get to the central file_backup folder but it appears empty.
 I have checked options from the save_as menu and it is se to save 5 backups.
Tue, Oct 14, 2008 at 3:20:09 PM | Backup files
robinballew
robinballew Avatar
3 Stars: 4 Votes
If you just enabled worksets you might not have any. Have you made some changes and saved the changes. Are you still working in the Central file?
BallewDesigns.com
Tue, Oct 14, 2008 at 3:42:11 PM | Backup files
Shaunab
We have been working on local files for three days now. No one has opened the central file since we started worksharing.  There have been several changes and saves to two different local files on two different machines.  Neither machine is saving any backups nor is the central file.  Luckily we aren't desperate to get a backup but we noticed that if we do need one in the future they are not there.  I have attached a "print screen" of my central file _backup folder viewed from the "file/backup" menu. I am sure there is something we are missing here but I cant figure it out. Thanks for your help.
Tue, Oct 14, 2008 at 4:09:35 PM | Backup files
When you have work sharing, the backup information is no longer saved in a bak file.
Tue, Oct 14, 2008 at 4:11:46 PM | Backup files
robinballew
robinballew Avatar
3 Stars: 4 Votes
Couldn't view the file. Just to be clear, local files do not create back up files. You have to browse to the Back up folder in the central file. I assume everyone is saving to central and everone else can see the updates on there local files. The only other thing I can think of is to do an on-line meeting so I can see your set up.
BallewDesigns.com
Tue, Oct 14, 2008 at 4:21:33 PM | Backup files
Shaunab
Yes everything you stated is correct.  I would be willing to try an online meeting, not sure out internet is fast enough but we can try.
Tue, Oct 14, 2008 at 4:31:56 PM | Backup files
robinballew
robinballew Avatar
3 Stars: 4 Votes
I can do it tomorrow after 9:00 am eastern. I didn't see your email so just send me an email and I will send you directions for the meeting.
BallewDesigns.com
Tue, Dec 23, 2008 at 12:04:37 PM | Backup files
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
So I too have a problem with my file.  It crashes everytime I try to edit, move or create a grid.  It's not once in awhile, it's everytime.
Now just like Shaun, I have gone to File/Backups...  and gone to both emy Local_backup and Central_backup folders and there are no files that Revit can read in there.  So I can't recover diddly.  Is there a specific way to recover Workset files?
Thanks,
Lorne
PS-we've been working on this project for months, so we have saved plenty of times for Revit to save into the backup folder.  Thanks.
Denver, CO
Revit Architecture
Tue, Dec 23, 2008 at 12:51:41 PM | Backup files
robinballew
robinballew Avatar
3 Stars: 4 Votes
Please describe the process you are using to determine if you have back-up files.
BallewDesigns.com
Tue, Dec 23, 2008 at 1:00:28 PM | Backup files
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Well, I open revit, then go straight to File/Backups...  Then I navigate to my Central backups folder: Project name_backups.  I open that, and there are no files to select.  I also try the same thing with my Local file backups folder, and still no files are in there.
I also have tried this while having the Central file or Local file open.  Still no files or options to select for backup.
I hope that explains it.  I didn't take any other action.  Although, now I have opened a file that was saved on our server and I am redoing all the work from yesterday.  But that's the best I could do since Revit doesn't seem to be backing files up.
Denver, CO
Revit Architecture
Tue, Dec 23, 2008 at 1:12:41 PM | Backup files
#13
robinballew
robinballew Avatar
3 Stars: 4 Votes
I would open the Local file you want to find backups for. Goto File/Backups.. browse to the back up file and click "open" it is not looking for you to find a file. Just the location. When you click "open" it will show the dates that are available. See attached images.
BallewDesigns.com
Tue, Dec 23, 2008 at 1:44:15 PM | Backup files
#14
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
wow, what an oversight.  Thank you for your help.
Lorne
Denver, CO
Revit Architecture
Tue, Dec 23, 2008 at 1:48:36 PM | Backup files
#15
robinballew
robinballew Avatar
3 Stars: 4 Votes
Revit has some hard to understand dialog boxes..Not always clear as to what you need to do...Good luck with your file.
BallewDesigns.com
Recovering a file from Backup Files W/O/ the original File
Fri, Feb 6, 2015 at 9:40:44 AM
can you save backup files to a different folder? [ 1 2 3 ]
Wed, Sep 16, 2015 at 4:57:05 PM
39
No rollback files or backup .rvt files
Mon, Jun 27, 2011 at 2:56:15 AM
save 2 backup files
Tue, Dec 4, 2012 at 6:51:29 AM
backup files
Tue, Feb 13, 2007 at 6:50:36 AM
Page generation time: 1.3965
