Forums >> Revit Building >> Technical Support >> Import PDF's
17 Posts No Rating |
Is there anyway to import a PDF into a revit drafting detail?
----------------------------------- Morss Medical Architecture |
I don't think so, but with "AllPlan Version 2008" you can import PDF and "He" convert pdf file in "Lines" then it just export to dwg...
Edited on: Mon, Oct 13, 2008 at 3:26:43 PM
No, but if you have Adobe Acrobat you can open and save it as a JPG. If you don't you can do a screenshot of it and save out the image and import that...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
also if you adobe illustrator you can open it, save out as dwg and bring that into revit.
PDF's & Excel |
Mon, Dec 12, 2016 at 6:17:38 PM
Printing PDF's |
Tue, Oct 26, 2010 at 11:21:57 AM
Autocad imports PDF's. Is there anyway Revit does that? |
Mon, Feb 1, 2010 at 5:06:18 PM
Problem import Autocad file that contains ''proxy entities''. |
Wed, Mar 17, 2021 at 7:38:19 AM
Can't figure out PDF printing. Help! |
Tue, Sep 12, 2006 at 4:39:07 PM
Members: | 2116731 | Objects: | 23197 | Forum Posts: | 152299 | Job Listings: | 3 |
