41 Users Online (40 Members):
Forums >> Revit Systems >> Technical Support >> Automatic Annotation ?
16 Posts No Rating |
Hi there, In abs when you drew up some ductwork, you had an option you could tick that turns duct size annotation and flow arrows on/off. Now im using revit MEP 2009 and i cant seem to find any options like that. The only way i see is by drawing it all > then going around and tagging it. For the sake of being lazy does anyone know of an option in revit that will help? Cheers
Ok i found the solution.... a simple icon that says "on/off tag on placement" when you click the duct/pipe tab... xD Now is there anyway to remove the unit type? i want to remove the mm (i.e. 200mmx200mm) Tried editting the tag etc but cant seem to find a way. Any help would be sweet as.
automatic annotations? |
Thu, Mar 1, 2007 at 6:43:51 AM
Object Count Annotation |
Fri, Feb 11, 2005 at 4:06:29 PM
Automatic extension gate |
Wed, Dec 26, 2012 at 11:56:03 AM
Annotation Object Styles [ 1 2 ] |
Thu, Dec 17, 2009 at 11:56:38 PM
15
sloped annotation symbol text |
Mon, Aug 15, 2011 at 8:04:20 PM
Members: | 2022352 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
