74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> Problem creating railing with intermediate newel posts
22 Posts No Rating |
Hi, I'm trying to create a balcony railing with intermediate posts every 5' and balusters every 4". What I end up with is the intermediate posts every 5' and ONE baluster offset 4" from the posts each time. So it's post, baluster, big empty space, repeat. What am I doing wrong ? : ) Many thanks, JF
![3 Stars: 2 Votes](/images/stars_3.gif) |
You need to define the entire pattern from post to post. So, if you want to have a pattern that repeats every five feet with a post and then ballusters at 4" o.c. between the posts, make a pattern that is something like this (Post - distance from last = 6", 3/4" square balluster - distance from previous - 6", 3/4" square balluster - distance from previous - 4", 3/4" square balluster - distance from previous - 4".......keep on adding ballusters in until the field for Pattern Length is 5'-0".
![robinballew Avatar](user_avatar/12071.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
Also on long runs you can just add a "Split" in the sketch line. At the split it will use the Newel defined for Corner post.
----------------------------------- BallewDesigns.com |
Split the line...... duhhhhh. Thank you thank you thank you. That's what i needed. And I'm guessing I'd use the "define the entire pattern" option if I had different panels within the same railing. Thank you both. JF
![Prophecy99 Avatar](user_avatar/66940.jpg)
72 Posts No Rating |
spliting the line SWEET, thanks robin
----------------------------------- Imagination reveals truths reality obscures. |
intermediate posts in railings |
Tue, Oct 12, 2021 at 12:27:49 PM
Baluster inside Newel Post revit 2014 |
Wed, Mar 26, 2014 at 2:54:06 AM
plan view cut plane inexplicably omits objects that it cuts. |
Tue, Mar 3, 2009 at 3:54:46 AM
Railing Posts Alignment |
Thu, Dec 4, 2008 at 8:10:43 PM
stair newel post does not go to treads |
Mon, Sep 19, 2011 at 1:57:25 PM
Members: | 2016941 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
