107 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering glass with pattern 2009
Sat, Oct 11, 2008 at 9:57:36 PM | Rendering glass with pattern 2009
niro
Hi,
How do you put a pattern as an interlayer in the glass?  AKA silk screen or fritted glass?
basically I am trying to create laminated glass with a pattern sandwich in between 2 layers of 1/4" glass.
I tried decals, but couldn't get it to work.
the other way I can think of is actually model the laminated glass.
anyone got any idea?
Mon, Oct 13, 2008 at 3:27:21 PM | Rendering glass with pattern 2009
mthurnauer
3 Stars: 2 Votes
I did a quick test. It looks like a good start is to duplicate the default Glass Block material in Revit and then make your own image map for transparency and you can probably just delete the bump map.  I cannot tell in my test renderin if it is applying the frit to both the front face and the back face.
Rendering glass in revit 2009 [ 1 2 ]
Tue, Aug 4, 2009 at 12:02:07 PM
23
Modeliing a firt pattern for rendering in Revit
Mon, Sep 19, 2011 at 10:18:54 PM
making glass floor in revit 2009?
Sun, Mar 15, 2009 at 3:35:00 AM
Family Questions in 2009
Wed, Dec 17, 2008 at 10:35:54 AM
glass transparancy
Wed, Jul 9, 2008 at 6:20:43 AM
Page generation time: 0.8072
