136 Users Online (133 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> help with .pat custom file.
Fri, Oct 10, 2008 at 1:26:43 PM | help with .pat custom file.
jmqrsq
5 Stars: 3 Votes
can anyone help me? i am trying to create a .pat file to look like this:
16"x16" and 8"x8" squares in this pattern.
Fri, Oct 10, 2008 at 4:56:47 PM | help with .pat custom file.
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Try this one.
Fri, Oct 10, 2008 at 7:35:48 PM | help with .pat custom file.
jmqrsq
5 Stars: 3 Votes
See I knew someone could help me! Thanks a ton man. I have been pulling my hair out trying to figure out the .pat file rules and how to's. I really appreciate it!!!!
Fri, Oct 10, 2008 at 7:36:54 PM | help with .pat custom file.
jmqrsq
5 Stars: 3 Votes
any chance you can explain what the number are doing exactly? no big deal if you do not have time. I just need to figure this ou once and for all.
Mon, Oct 13, 2008 at 5:36:58 AM | help with .pat custom file.
tim123
4 Stars: 19 Votes
There is an explanation in hte Revit.pat file (not the metric one).  Work through this - once you get the idea then it is fairly logical.
Mon, Oct 13, 2008 at 8:25:57 AM | help with .pat custom file.
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If you look at the top of the file I sent you, you will see a text string explaining each section in a line. It is a little confusing sometimes but basically what a pattern does is array a series of lines that include dashes and spaces. Anyway I usually have to do a lot of trial and error before I get it right so don't worry about not understanding it right now. If you study on it long enough it will eventually make sense.
Revit 2012, cannot import custom pattern from .pat file
Wed, Dec 30, 2015 at 8:31:18 PM
Custom PAt File Help Please!!!
Thu, Oct 14, 2010 at 7:46:26 PM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
custom pat files
Fri, Oct 21, 2005 at 3:13:23 PM
Stray Lines in custom Revit fill pattern
Mon, Jul 8, 2013 at 8:02:44 AM
Page generation time: 0.7031
