65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Copy Dimensions
Fri, Oct 10, 2008 at 1:06:34 AM | Copy Dimensions
Jimbooo
Hi,
I have a problem i hope someone can help me with.We have dimensioned level 1 and our level 2 are more or less identical. Is there a possibility to copy dimensions from level 1 to level 2 ?I get a answer "elemts where deleted" when i try to copy.
Be grateful if anyone can help me =)
Fri, Oct 10, 2008 at 3:16:57 AM | Copy Dimensions
tim123
4 Stars: 19 Votes
I don't have a problem doing this.  Copy the dimensions to the clipboard, go to the relevant level, paste aligned and choose same place.  If the geometry is the same you should not have a problem.
Fri, Oct 10, 2008 at 7:26:59 AM | Copy Dimensions
Your problem probably occurs becausee you have dimensioned to elements that are not in the view you are copying to.  You really have to pay attention to what your dimensions are referencing when you place them.  For instance, if you have a detail line in the same location as a wall, and you think you are dimensioning to the wall, you may be mistaken.
Isolate dimensions
Mon, Jun 1, 2009 at 8:05:44 PM
linked in model not able to move
Fri, Feb 11, 2011 at 6:41:51 AM
Change imperial to metric
Wed, Mar 11, 2009 at 9:20:25 AM
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:37 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:09 PM
Page generation time: 0.4073
