71 Users Online (69 Members):
Forums >> Revit Structure >> Technical Support >> Batch Plotting
We're using RStruc 2009 and yesterday we installed a new KIP 5000 print/copy/scan thing. What I want to be able to do is Batch Plot. For me, that means that if I have a set of 4 sheets and I want 10 copies of that set, I should be able to batch plot the set and the KIP should collate them properly. I first tried using Revit's plot dialog box. I selected the sheets I wanted, told it that I wanted 10 copies, and the KIP plotted 10 of the 1st sheet, then 10 of the 2nd sheet, etc., etc. That's not good. So, I installed Autodesk's new batch print extension for Revit 2009 . . . and seemingly, it doesn't allow you to plot more than 1 set. So, I'm asking myself, "self . . . what good is it?" Am I missing something simple? Is there a good way to make this happen? I know of a few work arounds but . . .
I am currently using RAC 2008 but i suppose the options are the same in 2009 too. When you go to File --> Print you get the window shown in the picture. From print range--> selected view sheets you pick your drawings. When in options --> number of copies you put more than 1, then you should be able to tick collate. Maybe you just forgot to press that?
----------------------------------- www.kaliakatsos.gr |
I did notice the collate feature in the plot dialog box but . . . not until AFTER I started this thread. However, it doesn't work . . . at least not with the kip. There's even a collate feature (check box) in the KIP 5000 printing preferences (properties). I've tried every combination of KIP's collate feature and Revit's collate feature and . . . same results. I get 3 copies of sheet 1, then 3 copies of sheet 2, etc.
5 Posts No Rating |
i am currently having the same problem. there has got to be a way to "collate" correctly. i cant get it to work on any printer so i am almost positive that the printer is not the problem but the program rather. if anyone has a suggestion on correctly printing batched sets i would appreciate it. i would rather not print one set at a time if there is a way around it...
There is a batch plot utility add on for Revit - I don't remember where it can be found ... On Autodesk site I think
13 Posts No Rating |
This is obviously a problem with Revit. Have the same problem with collating sets. I have tested my printer using Word and it collates word docs perfectly. Does any one know a fix? It will save alot of time and anguish.
we have stuck to plotting out to pdf....it's simple and actual helps create an archive....you can collate in set...should work fine with the KIP
I really want this to work...some good things some bad |
Batch printing sheets from multiple files |
Wed, Feb 17, 2010 at 2:45:00 PM
Batch plotting folder location |
Thu, Jan 21, 2016 at 1:40:58 PM
Revit Family Batch Updater - Anything like this? |
Wed, May 12, 2010 at 6:03:46 PM
Some sheets plotting rasterised for no reason - revit building 2013 |
Thu, Jan 30, 2014 at 7:16:15 AM
REVIT 2012 BATCH CONVERTER |
Thu, Jun 30, 2011 at 4:27:10 PM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
