64 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Levels - True v's datum
Wed, Oct 8, 2008 at 9:51:32 AM | Levels - True v's datum
bdbhoy
1 Stars: 1 Votes
Can anybody help? I've got my levels in sections set to real contour readings. Is there a way to simply reset them back to a ground floor datum of 0.0m?
Thu, Oct 9, 2008 at 1:30:05 PM | Levels - True v's datum
robinballew
robinballew Avatar
3 Stars: 4 Votes
Are you using shared coordinates? If you are you can cange the Levels Coordinate between Shared and Project. If not you will have to relocat the project using "Relocate Project". I would set up Shared Coordinates before relocating.
BallewDesigns.com
Datum Levels
Tue, Jul 1, 2008 at 4:18:53 PM
Relative levels
Mon, Dec 14, 2009 at 2:29:26 PM
Basement Datum Level Line: Now you see it, now you don't
Fri, Nov 18, 2011 at 11:41:49 AM
Topographical Datum Points
Wed, Aug 18, 2010 at 11:04:41 AM
Datum Control
Fri, Apr 21, 2006 at 6:39:23 AM
Page generation time: 0.9048
