84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> How do I create a sweep with a light source?
Tue, Oct 7, 2008 at 3:31:23 PM | How do I create a sweep with a light source?
sniper22904
I have made a light cove profile, but do not know how to give it a light source for the continuous light in the cove. I made the cove a profile so that it is easier to use as a sweep versus having to redraw it every time for every project.
please help.
Mon, Nov 17, 2008 at 1:33:08 PM | How do I create a sweep with a light source?
jlights
3 Stars: 2 Votes
You need to create a lighting fixture family that corresponds to a the lighting fixture you plan to put into the cove. The lighting fixture family will have the light source built into it, and you can assign an ies file to it if you want to use it in renderings. Then insert as many instances of the fixture family as it takes to fill the cove, just as you would in the real world (that's the nature of Building Information Modeling). Also be sure to set the light source object to Photometric web in element properties, or it won't render properly.
Hope this helps.
jlights
Mon, Nov 17, 2008 at 1:53:17 PM | How do I create a sweep with a light source?
4 Stars: 203 Votes
Hi, check this video I made a few weeks ago and see if this is what you need... http://screencast.com/t/Qu0Hq1MG5
Issues with Light Source in Revit 2013
Wed, Jun 5, 2013 at 2:48:23 PM
Light Source in Revit - the dead horse
Thu, May 6, 2021 at 4:34:17 PM
13
Downlight with hidden light source
Sat, Nov 23, 2013 at 8:19:33 AM
Light source inside the light fixture
Fri, Feb 22, 2013 at 7:24:32 AM
rendering light source
Mon, Dec 19, 2011 at 3:50:41 PM
Page generation time: 1.0934
