61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Varying slab thickness
Tue, Oct 7, 2008 at 12:09:52 PM | Varying slab thickness
jdam
jdam Avatar
Does anyone know how to create a slab that is 12" thick on one end and 11" thick on the opposite end?
Tue, Oct 7, 2008 at 12:17:27 PM | Varying slab thickness
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
floor,floor properties,edit/new, structure, variable (check box on the right column)
 http://screencast.com/t/ydFLK6641
Tue, Oct 7, 2008 at 12:23:08 PM | Varying slab thickness
jdam
jdam Avatar
That's it, huh? Cool, thanks. So how does it know to be 1" thinner? (Sorry...still a noob)
Tue, Oct 7, 2008 at 12:30:26 PM | Varying slab thickness
jdam
jdam Avatar
Tue, Oct 7, 2008 at 12:49:15 PM | Varying slab thickness
alabaster2513
3.5 Stars: 25 Votes
once you set your variable parameter you can select your slab and in the options bar you will get 4 shape editing commands. the first one lets you select the existing control points and change the elevation either by clicking and dragging or by entering a numberic elevation.
Tue, Oct 7, 2008 at 12:53:22 PM | Varying slab thickness
jdam
jdam Avatar
got it...thanks alabaster!
Suspended Slab problem
Thu, Aug 19, 2010 at 3:15:33 AM
The same (one wall) to have varying thickness in its width dimension not height?
Thu, Mar 1, 2012 at 10:17:44 AM
varying slab thicknesses
Thu, Sep 27, 2007 at 2:12:32 PM
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:45 AM
slab schedule
Mon, Apr 19, 2010 at 9:10:28 AM
Page generation time: 0.3222
