53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Inventor files
Does anyone know how to create a file in inventor and import it into revit?
13 Posts No Rating |
if you can export the file to a dwg, dxf, you can import it directly into revit. if this does not work you and you can import it into 3ds max or viz instead than save out as a 3ds. then you can import that 3ds into autocad then save as dwg. then you can import to revit.
a bit of a bugger around but gets the job done.
You can import , saving your Inventor file as .SAT
and import into Revit as a .SAT file .
2 Posts No Rating |
Is There any way to import .sat to Revit 9.0 with the color?
Edited on: Mon, May 14, 2007 at 10:49:48 AM
Inventor files to revit components |
Wed, Oct 12, 2011 at 8:38:24 AM
Inventor to Revit Structure 2010 or 2011 |
Fri, Dec 10, 2010 at 5:45:29 AM
Inventor files into revit |
Tue, Jan 22, 2013 at 7:28:04 AM
adsk files from inventor to revit |
Thu, Feb 27, 2014 at 7:11:47 AM
creating models in Inventor and exporting them into revit |
Sun, Mar 6, 2011 at 4:53:21 AM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
