Forums >> Revit Systems >> Technical Support >> local file error message
A coworker has recieved the following error which results in his file being un openable, and he has to re-create his local file from the central every time. What is causing this? He didnt actually move any file locations that we are aware of.
Your co-worker is opening the central file everytime if he is getting this message. Make sure he is actually doing a save as to make his local and that he is actually opening the local. We use the terms central and local in our appropriate file names.
He called me over last time it happened, and he was indeed in his local file. -We use xb for our central file xe for our electrical file and xm for my mechanical file. I did check to see if he had accidently detached himself from central or anything similar. He has been having computer issues which resulted in me and our tech guy having to re-install windows/revit last week. -The computer wouldnt boot, and got stuck in some kind of blue screen cycle. I asked the tech to do another scan tonight, but wanted to check for user errors first. We are both working in a local file of this central, and I am doing fine with no errors. We both use 64 bit windows, but I have a better graphics card (which shouldnt matter for this problem) I have both set to not use open gl even though mine has the option. It seems to work better that way. I apreciate your help....
Edited on: Mon, Oct 6, 2008 at 12:34:54 PM
new information: He opened my condensing unit family to edit the electrical connector, and after he edited it, the file was no-longer saveable. I had to delete it, and go to one of my backups and rename it, then re-load it into the project. Im really perplexed!!!!!!
95 Posts No Rating |
Did you ever find a solution to this problem? I'm having the same issue. http://www.revitcity.com/forums.php?action=viewthread&thread_id=20046
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer |
Revit Ceiling Causing "Serious Error Has Occurred" Message |
Thu, Aug 29, 2013 at 3:01:57 PM
Error - Local File Resides in Central File Location |
Fri, Apr 9, 2010 at 8:34:55 AM
Can not create local file from Central |
Tue, Mar 6, 2012 at 11:57:26 AM
Keynotes Error Message |
Mon, Jan 24, 2011 at 9:12:17 AM
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 9:12:33 AM
Members: | 2119068 | Objects: | 23205 | Forum Posts: | 152311 | Job Listings: | 3 |
