118 Users Online (117 Members):
Forums >> Revit Building >> Technical Support >> demolish siding
2 Posts No Rating |
I have a existing house with 6" metal siding, for new construction we are going to replace the siding to 2 3/4" wood, there any way I can phase existing walls to show the 6" as existing and 2 3/4" for the propose. We have History review presentation and we have to show existing and new. thank you for any help
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
I believe the simplest way is would be to create two walls, one being the 6" wall with sheathing (I assume the sheathing is going to remain). Then create another wall that encompasses the siding. You then need to draw the two walls adjacent to each other, and then demolish the one with the siding and add your new, third wall on the new phase. HTH
![robinballew Avatar](user_avatar/12071.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
I would make the existing wall with the existing siding that is under the Vinyl. Add the New Wall Just vinyl. (3/4" . The trick is that you have to use the Join Geometry tool to get the windows to cut through the 3/4" wall. When you demolish the vinyl wall you should see the existing siding. Good Luck PPlacko
----------------------------------- BallewDesigns.com |
Demolish wall alyer |
Fri, Aug 1, 2014 at 10:37:24 AM
demolish door with out infilling opening |
Fri, Jun 5, 2015 at 9:30:39 AM
Metal siding |
Mon, Mar 16, 2009 at 9:44:10 PM
Wall Sweep/Siding |
Sun, Feb 17, 2008 at 12:11:00 PM
Demolish Tool |
Thu, Sep 13, 2012 at 6:20:41 PM
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
