48 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> family rotate
Sun, Oct 5, 2008 at 5:09:18 AM | family rotate
marc
Is there someone who knows how this was made? (attachment).I can make a family with a variable numbers of elements and with variable angle (for instance sunscreen).But only when it rotates in the xy-plane.I found the example (attachment) on internet  but I don't know how it was made. There are parameters for width etc but where are they defined? It is not a family that was loaded in this family I suppose.
Sun, Oct 5, 2008 at 7:35:08 AM | family rotate
robinballew
robinballew Avatar
3 Stars: 4 Votes
It looks like the parameters you are looking for were added in the Sketch mode. Just edit the family and look at it from the side. You should see the missing parameters.
BallewDesigns.com
Sun, Oct 5, 2008 at 9:47:01 AM | family rotate
marc
That's the problem: I dont's see the dimensions (parameters) not in sketchmode.
Sun, Oct 5, 2008 at 12:14:39 PM | family rotate
4 Stars: 203 Votes
Hi, when you pick in the object and go to "Options Bar" click in "Edit", now you are in "Sketch Mode" the lines turns magenta, then you are able to see the "Louvre Thk and Louvre Size" dimension... change to 3D view or Left/Right view, see image attached... (BT, change the scale if there is too large)
Sun, Oct 5, 2008 at 2:03:39 PM | family rotate
marc
Thanks!Problem solved.
Can't Rotate Revit Family Created
Mon, Dec 3, 2012 at 2:21:25 PM
Rotate of family
Wed, Feb 24, 2010 at 1:32:33 AM
Made a new family but ant rotate it properly
Mon, Jun 13, 2011 at 12:32:46 PM
3d rotate
Fri, Sep 28, 2018 at 7:16:27 AM
How to rotate family componenent? Example Dryer
Thu, Jul 14, 2005 at 2:28:40 PM
Page generation time: 1.1202
