24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit intu 3DSMax
Tue, May 3, 2005 at 4:36:30 AM | Revit intu 3DSMax
VonVan
Please, I am using 3ds max instead of Viz. Can I link the revit files to Max like to viz. I dont want to have istalled Viz and Max only because of transfering the files from revit to viz and than to max. Thank you
Tue, May 3, 2005 at 7:32:12 PM | RE: Revit intu 3DSMax
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I believe the addon for viz also works with max... But don't quote me on that as i haven't tried it.
Tue, May 3, 2005 at 9:24:44 PM | RE: Revit intu 3DSMax
loganam
I just upgraded to revit 8 and downloaded the plugin for viz 2005...how do you use it....where is it in revit.
Tue, May 3, 2005 at 11:02:34 PM | RE: Revit intu 3DSMax
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The plugin is for viz not revit... Just export out a 3D Dwg out of revit and providing the plugin is installed in viz it will be able to interpret all the accurender material settings that were previously setup in revit.
Saving to 3dsMax?
Mon, Jul 10, 2006 at 3:03:50 PM
Linking Revit to 3dsmax 9 sp1
Tue, Jun 26, 2007 at 11:05:39 AM
Revit to 3dsMax for GPU utilization
Fri, Dec 21, 2012 at 12:12:36 PM
revit file too heavy when importing into 3dsmax
Fri, Sep 11, 2009 at 1:13:55 PM
how to transform my 3d from 3dsmax into technical drawing
Mon, Jan 19, 2009 at 1:32:52 PM
Page generation time: 3.5505
