74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Structural Element Tags
Fri, Oct 3, 2008 at 11:14:37 AM | Structural Element Tags
nmartin
Is there a way to have structural tags default to display with a lower case x between the numbers? ex: W10x15 or HSS8x8x.500
Also, is there a way to make HSS tags default to display the last number as a fraction and not a decimal?
I have a feeling this information is locked in library we import the elements from, but I just want to be certain.
Fri, Oct 3, 2008 at 11:27:11 AM | Structural Element Tags
TJKENNEDY
3 Stars: 2 Votes
The tag is reading the Type Name, so rename the type.
structural truss element not visible in section
Sun, Jun 28, 2020 at 7:05:04 AM
listing an arch model element in a structural model
Tue, Dec 8, 2009 at 3:33:37 PM
[Revit 2010] Mass form usable as generic model or any structural element?
Thu, Jun 4, 2009 at 7:44:07 PM
Linework applied to structural elements
Fri, Jan 23, 2015 at 9:39:03 AM
Can not tag beams
Fri, May 8, 2009 at 3:45:13 AM
Page generation time: 1.1209
