116 Users Online (115 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Baluster not connecting to rail
Thu, Oct 2, 2008 at 11:12:19 PM | Baluster not connecting to rail
dylan88
I have tried a number of different settings and different Rail types, but having a issue with the Baluster posts not connecting to the under side of the rail (see image attached).
 This seems to be happening in all our projects created and/or worked on in Revit Architecture 2009 and Structure 2009.
 Any ideas would be great.
Thanks
Fri, Oct 3, 2008 at 6:53:24 AM | Baluster not connecting to rail
3.5 Stars: 395 Votes
It may be that your rail profile was modified and is not at its origin.
Sun, Oct 5, 2008 at 5:52:29 PM | Baluster not connecting to rail
dylan88
Thanks WWHub, Ill have a look at that.
It also happens to all the styles of rail types (guard rail, hand rail etc) so im thinking its something else rather then a profile or family, but im not sure...
Sun, Oct 5, 2008 at 11:23:26 PM | Baluster not connecting to rail
mgr2820
2 Stars: 2 Votes
If your rail is set correctly, I would check the baluster properties. In the project browser, go to families - railings - then right click the properties of the baluster in question. Is there a height parameter? What is it set at?
When you create parameters for balusters and handrails, you cannot access them through the element properties like component families. Because railings are system families you cannot select the individual properties of loaded profiles or, balusters. You need to go to the project browser and access them through the families drop down. I suspect that your balusters have a height parameter that is set too low for your railing. If not, have you checked the top offset in the type properties of the railing itself?
Mon, Oct 6, 2008 at 12:36:08 AM | Baluster not connecting to rail
dylan88
Thanks mgr2820, It is the baluster, when i change the rail hieght the baluster still stays the same height, iv gone to its properties via the project browser as you said, but there doesnt seem to be a height parameter??I opened the baluster family and found it had a hieght of 750, which was the height they were in my project, but now that iv removed that parameter, the baluster still wont attach its top to the under side of the rail.. it will only go by the height it is in its family
 Iv attached a screen shot of both the family and the railing in the project, the circled area was 750, but i changed it to 1000mm then removed the dimension and loaded it into the project and you can see the results.
Mon, Oct 6, 2008 at 1:13:14 AM | Baluster not connecting to rail
mgr2820
2 Stars: 2 Votes
Is this a baluster downloaded from the web library? I might check to make sure that the extrusion is actually locked to the reference planes that define the height. Also, is your project in metric?
  • You might open a new revit file and check the default railing settings- then compare with what is in the file your having trouble with. There are alot of offsets in the railing type properties, double check this.
  • Is your project in metric? The baluster and project should be using the same units.
Judgung by your screen shot- it seems like the balusters are correct on the stair, but, incorrect on the landing, now.
Are you creating the railing after you've modeled the stair? Perhaps, you need to move the transition where the railing goes from slope to flat? You may have to override the railing from auto detect - to defining it as slope and flat- then adjust the posiition until geometry is correct.
Wed, Oct 8, 2008 at 9:50:46 PM | Baluster not connecting to rail
dylan88
Yep, my project is Metric.
As far as i know it is standard Revit railing?
I will do as you suggest and compare it to a defult project, this may have something to do with it as its from my companys template file, which has been around from before my time working here (2 years) and it may have not liked the move to the lastest revit.
I will post updates when i get a chance to check it all.
 Thanks for the help
Mon, Oct 13, 2008 at 7:09:33 PM | Baluster not connecting to rail
dylan88
Thanks mgr2820, After comparing a Defult revit template to our companys template i found that the railing was working fine in the defult template. Im going to delete all the railing families, profiles etc from our template and reload them and hopefully they work from now on. Thanks for the help!
Mon, Oct 13, 2008 at 10:09:26 PM | Baluster not connecting to rail
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you have the baluster family type set to be "Post" then it doesn't attach to rails.  Try turning this option off and then it will automatically attach.
HTH.
Regards,
Chris.
Mon, Oct 13, 2008 at 10:35:47 PM | Baluster not connecting to rail
dylan88
Hi Mr Spot,Sorry but where do i turn that off...?
Wed, Oct 15, 2008 at 1:58:13 PM | Baluster not connecting to rail
Hawkmoon36
If you open up the baluster family to edit, there's a check box at the top that says "post".
Wed, Oct 15, 2008 at 5:01:50 PM | Baluster not connecting to rail
dylan88
Thanks, it was already unchecked. I have since loaded new railing types and baluster types in and they all seem to work so dont know? Thanks everyone for the help
Wed, Nov 30, 2011 at 4:57:53 PM | Baluster loading into revit project
#13
zaheerjogee
I have been trying to add a baluster (square w ball revit 2012) but it just does not drag into the drawing like the other families. I am designing an internal layout for a bank and need those posts for showing how the people should enter the que please could somone help me.....
Wed, Nov 30, 2011 at 5:32:02 PM | Baluster not connecting to rail
#14
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Make sure you use the 'ballaster' family template to create the family or modify and rename an exiting family from the Ballaster folder.
Load it into the project | Insert > Load Family.
It will be filed under the 'Railings' category in the project browser.
It will then be available in your Railing famiy.
rail 1 and baluster heigth
Tue, Nov 8, 2011 at 10:40:22 AM
Set baluster on Bottom Rail
Thu, Mar 29, 2012 at 8:59:47 AM
2015 use baluster per tread on stair (with no top rail?)
Thu, Sep 3, 2015 at 4:50:57 PM
Rail not Attaching to Baluster
Sat, Oct 10, 2009 at 8:14:19 AM
Top rail offset
Wed, Jun 21, 2017 at 11:14:51 AM
Page generation time: 0.2653
