59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof - Inner loops of a footprint sketch may not have slope-defining lines.
Thu, Oct 2, 2008 at 4:02:31 PM | Roof - Inner loops of a footprint sketch may not have slope-defining lines.
edratliff
Basically I'm trying to create a roof made of glass. It's rather large (2016m in diameter).
I have a tower in the center of the roof. I need the outer edge of the roof to rest on the top of a 10' wall, and 30' high on the inside of the roof. So thats a 30' raise of a 1008m run. 30'/1008m. I get this error message: "Inner loops of a footprint sketch may not have slope-defining lines."  --I searched the forum and saw that someone said to split the roof in half and it would work. When I did that I got a message sayign "Can't create footprint roof."
 Can't win here Puh Whats going on? Render below showing overall situation.
Thu, Oct 2, 2008 at 4:09:29 PM | Roof - Inner loops of a footprint sketch may not have slope-defining lines.
Not sure your image helps.  Do you have a square with a square hole in the middle?
That's right - the outer lines define the slope.  If the inner lines are set as defining, they are trying to control the same surface and that can't be.
Thu, Oct 2, 2008 at 4:20:17 PM | Roof - Inner loops of a footprint sketch may not have slope-defining lines.
edratliff
Thanks! I really need to get a book...Instead of turning to you guys. But thanks!
Roof Error Message
Tue, Oct 18, 2005 at 9:01:51 AM
Roof with central atrium
Mon, Apr 7, 2014 at 7:30:19 PM
Sloping Garage Floor
Wed, Nov 7, 2007 at 2:51:16 PM
unable to make footprint roof
Fri, Mar 21, 2008 at 12:28:15 PM
Roof centerline
Fri, Nov 7, 2008 at 1:53:58 PM
11
Page generation time: 1.1010
