39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Material problems RAC 09
Thu, Oct 2, 2008 at 3:43:47 AM | Material problems RAC 09
wilson0207
Hi, i have explored the forums, F1 and even our subscription technical team until blue in the face, Hopefully someone on here can put me out of my misery.
I'm in the process of rendering a site layout of mine, and the problem im having is roof tiles are not rendering to my assined material.
i have created my own library of houses where i then import them as a revit link into my site layout. the original revit link has the correct materials assigned to the rendering, but when i render in the site layout, it shows up as the standard paint fill.
Both original files (ie revit link and site layout) have the same properties regarding roof tile and render material. the only way i have managed to achieve what i want is to physically delete the revit link and re-insert it. But obviously all orientation/rotation properties are lost for all my links on my site layout. And on a 300 house scheme, thats a big ball ache.
Any help more than appreciated.
 thanks
Thu, Oct 2, 2008 at 4:46:25 AM | Material problems RAC 09
4 Stars: 203 Votes
Hi, and in your "Site Layout" did you check in "Settings>Materials" if the "Roof Tiles" material has the "Image-JPG, PNG" like in your "Revit Link" file??
Thu, Oct 2, 2008 at 4:54:08 AM | Material problems RAC 09
wilson0207
Thanks for your reply
yes both files are the same
ie (Thermal_Moisture.Roof.Tiles.Spanish.Red.Colour.jpg)
when i bring my revit link into a new project it works.
its almost like theres a visibilty graphic override turned off, but i have searched and searched and searched
Thu, Oct 2, 2008 at 5:03:32 AM | Material problems RAC 09
4 Stars: 203 Votes
Hi, i see the email, i don't know but try to pick in that "ROOF" (i think it's a roof isn't??) and go to properties > edit/New and edit the Structural materials, pick in the material, duplicate with other name and change the material to "glass i.e." and check if change, owhwhwh by the way, do you have the same JPG in "BUMP" also??? can you put a screenshot in the materials settings with the material you want???? some images of that properties materials to i can check those properties of the JPG...
Thu, Oct 2, 2008 at 6:10:18 AM | Material problems RAC 09
wilson0207
that worked, great
as per usual
thanks again
Adding Material to Roof trim? RAC 2009
Mon, May 12, 2008 at 1:57:11 PM
RAC 2010 RENDER PROBLEMS
Mon, Sep 14, 2009 at 4:24:41 PM
Uninstalling RAC 2012 problems..
Fri, Sep 23, 2011 at 4:26:45 PM
Radiate material problems [ 1 2 ]
Sun, Mar 23, 2008 at 2:52:04 PM
18
split face not remembering material - RAC 2008
Thu, Nov 20, 2008 at 3:13:32 PM
Page generation time: 1.1639
