80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> Worksets >> Saving/unlinking a Workset Without Updating
Wed, Oct 1, 2008 at 11:05:31 AM | Saving/unlinking a Workset Without Updating
RevitCity07
We have one project with 2 Worksets.  The first workset is fully updated.  The second workset has not been updated in a few weeks, and since then, the design of the building has changed dramatically.  How can I unlink this second workset from the central file to save this previous work as a reference.  And do all of this without reloading?  Kind of like if we exported to Autocad right now from that file, but how can we achieve a standalone un-updated copy by using Revit?
Wed, Oct 1, 2008 at 11:17:56 AM | Saving/unlinking a Workset Without Updating
Worksets are not the same as design options.  If you have changed workset A and nothing has changed in workset B then so what?  Workset A does not directly affect workset B anyway.
Wed, Oct 1, 2008 at 11:24:13 AM | Saving/unlinking a Workset Without Updating
RevitCity07
Yes, but I want to move Workset B to another location and rename it, completely unlinking it from the central file so the changes I make in that can never be made to the central file.
Wed, Oct 1, 2008 at 12:24:51 PM | Saving/unlinking a Workset Without Updating
Worksets are part of the model and thus cannot be un-linked.  For instance - if you have furniture in an interiors workset, the furniture sits on a floor that may be in the architectural workset.  The furniture can not reside without the host floor.
You can always have two files and copy between the two ... you can have a file that only has the building and another file that copy monitors the building file but only has the furnishings.  But this process is not really using worksets.
Mapping of Materials in Worksets keep unloading when saving to central?
Wed, Sep 7, 2005 at 5:53:09 PM
Saving Elements to Separate Files
Thu, Feb 18, 2010 at 4:00:28 PM
Updating Central file (multiple users)
Fri, May 15, 2009 at 11:44:33 AM
Visibility Dialog Slow to Appear
Wed, Jun 1, 2016 at 8:28:14 AM
updating model
Mon, Aug 5, 2013 at 8:59:53 AM
Page generation time: 0.3397
