60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> Parameter Help needed
Hello there, I am having an issue with adding a couple parameters to a Code Room Tag. I am trying to get the Room name/Square footage/Square Footage Per Person/# of Occupants in room. My problem is getting the family parameters to link to the calculations Revit computes when I input the room occupancy type. So if I choose "business areas" in my Occupancy Tabulation Schedule it then calculates that to 100 SF Per Person and then calculates how many persons fit in that room. How do I get my room tag to show this info? Is it even possible? I already have these parameters in my project, but I can't get these specific parameters into my family. They appear in schedules, can I not link these project parameters to my family? Is there a new type of parameter I can create? Does this make sense? I have attached the file below. Thanks, Lorne
Denver, CO
Revit Architecture |
I am mildy confused, but I'm thinking your solution is having a shared parameter for the tags. Have you ever used shared parameters?
Yes I've used Shared parameters and that's the problem. I can't get the loaded shared parameters to link appropriately with the S.F. Per Person and Persons columns in the schedule. I tried to set a label with a parameter in the room tag, but then when loaded it's just question marks. I assigned it to Rooms Category under parameters too?? Does that make more sense?
Denver, CO
That one is beyond my knowledge, if you do figure it out please post the solution so i can rip you off!
Of course I'll share it. I just gotta find the answer...cuz I'm stumped. Anyone know??
Denver, CO
Help with formula needed |
Wed, Apr 9, 2014 at 10:47:20 AM
"group parameter under" changed upon loading into project |
Wed, Aug 11, 2021 at 3:16:03 PM
Parameter Formula Help Needed |
Thu, Oct 15, 2009 at 10:57:55 AM
Title Labels |
Sat, Jun 29, 2013 at 12:54:18 PM
Wall Based Plumbing Fixtures.. Elevation parameter.. help please! |
Thu, Oct 2, 2008 at 12:08:49 PM
Members: | 2030869 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
