Forums >> Community >> The Studio >> Revit 64 bit Native
Anyone using it yet? Is it the best thing ever?
5 Posts No Rating |
I'm installing it right now. We shall have to wait and see! Do you have to still install the september service pack after installing the 64 bit, or is that only for the 32 bit? Tab
11 Posts No Rating |
How did you get a 64bit version? I thougt it was only AutoCAD that came in 64bit....
I have installed it now. Not much to say yet. But read the "Know Issues" you will find that there are some few functions there will be lost i the 64bit version. It is also the workstations with more than 4Gb RAM that will gain advantage.
I'm going to give it a try on Vista 64 through bootcamp on a Mac Pro to see how things go, just need to get a little free time first. Still very curious if people with high end desktops are seeing a huge difference. Does the 64 bit multi thread your processor?
5 Posts No Rating |
Works wonderfully! I didn't know whether or not i should install the service pack, so I tried it and it wouldn't install, so obviously it is not required. I'm attempting my first rendering with it right now and will post results later. Tab
I'm using it on a Vista 64bit and there are no bugs jet. So if you have a Vista 64bit, use the Revit 64bit version. There are no reason not to do it.I'm also running with no pagefile. Works perfekt. I don't see a huge difference but it is now possible to use 8Gb RAM.
installed Revit-64 bit for 2 days now. no problems yet. running smoothly
