18 Users Online (17 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cant see wall material cut in plane
Mon, Sep 29, 2008 at 12:33:02 PM | Cant see wall material cut in plane
JohanEkstrom
Hi guys
 Emergency:
I cant manage to get the materials in the wall to show. I want the different layers in the wall to be visible in my plans.
- Ive changed the settings to "Fine". - Ive doublechecked the materials cut pattern.- No visibility overrides in "vv"
What am I missing???:o)
Mon, Sep 29, 2008 at 12:37:29 PM | Cant see wall material cut in plane
4 Stars: 203 Votes
And you change the scale in that view?
Mon, Sep 29, 2008 at 12:55:37 PM | Cant see wall material cut in plane
JohanEkstrom
Ive tried different scale just in case...but is there a particular scale needed to show it?
Mon, Sep 29, 2008 at 1:22:40 PM | Cant see wall material cut in plane
4 Stars: 203 Votes
Can you put some snapshots (like i have in attached) to see what it's happen? you check the scale, the VG, Fine mode, so what it's like your wall in plan when you create them?
Mon, Sep 29, 2008 at 1:30:30 PM | Cant see wall material cut in plane
JohanEkstrom
Thanks for your help. Ill put up a picture asap.
The wierd part is that the wall looks fine when I Preview it in Element Properties but nothing shows in plan no matter how much I seem to tamper with view settings...
Mon, Sep 29, 2008 at 1:55:07 PM | Cant see wall material cut in plane
JohanEkstrom
Mon, Sep 29, 2008 at 2:01:50 PM | Cant see wall material cut in plane
4 Stars: 203 Votes
Hi, try this change the scale in that view to 1:20 or 1:10, zoom to the wall and check if the pattern appears, right now you have the scale 1:200....
Mon, Sep 29, 2008 at 2:05:25 PM | Cant see wall material cut in plane
JohanEkstrom
Ive tried every scale possible...nothing changes. Not even with 1:10 and zooming forever...
Its 9 pm at the office and this has to be published before midnight. Driving me nuts :o)
Mon, Sep 29, 2008 at 2:17:30 PM | Cant see wall material cut in plane
4 Stars: 203 Votes
Can you put that wall in a file and send me by email to i take a look? thyphoon38@gmail.com
Mon, Sep 29, 2008 at 2:32:57 PM | Cant see wall material cut in plane
JohanEkstrom
You are the best and I wish I could do so...but the project has the highest safety-class at the office so I'll be hanged if I export something out of it.
I'll give it another hour and then I'll 2D the whole lot :o)
...but it really annoys me that its not working
Mon, Sep 29, 2008 at 2:36:05 PM | Cant see wall material cut in plane
#11
4 Stars: 203 Votes
Wait for the video... this is the video: http://screencast.com/t/Yq9BpcNZ
Edited on: Mon, Sep 29, 2008 at 2:36:59 PM
Mon, Sep 29, 2008 at 2:37:09 PM | Cant see wall material cut in plane
#12
JohanEkstrom
Mon, Sep 29, 2008 at 2:38:09 PM | Cant see wall material cut in plane
#13
4 Stars: 203 Votes
see the video:   http://screencast.com/t/Yq9BpcNZ
Mon, Sep 29, 2008 at 2:46:55 PM | Cant see wall material cut in plane
#14
JohanEkstrom
Havent tried that before :o)
Unfortunately it didnt work. I can override the entire pattern for the whole wall with that function, but I can not isolate it to the one material.
It has to be a View setting that is messed up or something...
Mon, Sep 29, 2008 at 3:08:27 PM | Cant see wall material cut in plane
#15
4 Stars: 203 Votes
Do you put some "Plan region" on that?, do you check the "view Range-Cut plane" in that view? do you check in the vp Walls like the image attached?
Edited on: Mon, Sep 29, 2008 at 3:11:36 PM
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:42 PM
5'8" wall will not be cut by cutplane
Mon, Nov 13, 2017 at 3:49:59 PM
wall no being cut in plan
Fri, Nov 6, 2015 at 3:24:59 PM
only show wall cut
Wed, Feb 16, 2005 at 9:37:32 AM
Cut plane hatch missing from one type of wall
Tue, Sep 20, 2011 at 9:54:20 AM
Page generation time: 1.6773
