50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Fill Pattern Weight
Fri, Apr 29, 2005 at 1:17:55 PM | Fill Pattern Weight
kfpopeye
Is there anyway to increase the lineweight of fill patterns on walls,similar to using the linework tool. On elevations I would like the fill patterns on walls close to me to be darker than those far away. Also I would like fill patterns on walls far away to be off completely.
Life is one of those things that people find hard to avoid. - Rowan Atkinson
Mon, May 2, 2005 at 6:30:23 PM | RE: Fill Pattern Weight
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
View depth stepping is not currently possible...
Thu, Dec 17, 2009 at 12:03:14 PM | Fill Pattern Weight
fpopa
I have a more simpler problem that maybe you could assist with.  How do you change the line weight on a wall pattern, period.... I don't care about the View Depth Stepping...
I got the Drafting Pattern Line Weight taken care of, but not the Model Drafting Pattern Line Weight...
Please Help
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:37 AM
Fill Pattern Weight + Appearance
Fri, Jan 9, 2009 at 4:40:45 PM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:25 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:02 PM
Split face pattern line weight (2009)
Tue, Aug 19, 2008 at 2:57:26 PM
Page generation time: 0.3414
