76 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> RAC 2009 Columns, Beams & Walls.
22 Posts No Rating |
Hi, I have a bit of an annoying problem since 2009 came out. The priority of structural elements seems to have been downgraded in favor of walls. Since masonry walls are often, if not always, reinforced with concrete beams, columns etc.. (at least in Florida they are), there are often concrete elements embedded in the walls. In 2008, joining a column / beam and a wall resulted in the wall being cut (as in real life.) Now it's the other way around. Embed sturcture in walls and the structure disappears. Every place that structure coincides with a wall, in any view, results in a missing chunk of concrete. Any ideas on how to go back to the happier days when structure actually showed up ? Or do I have to do everything in Revit Structure now and import it ? Thanks Jfmonod
Did you insert Structural Columns or Architectural columns in that?
Columns/Beams won't cut wall & wall beyond is visible |
Thu, Jun 21, 2012 at 9:19:31 AM
Walls and Structural Beams/Columns and Finishes |
Tue, Jul 19, 2016 at 3:46:11 PM
12
connections between beams & columns |
Tue, Apr 8, 2008 at 12:11:49 AM
Concrete columns behaviour before and after placing concrete beams |
Tue, Apr 1, 2014 at 1:58:43 AM
Can't select beams nor columns |
Sun, Mar 10, 2019 at 10:12:36 PM
Members: | 2057494 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
