53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> cutting a non-rectangular opening on arc wall? revit 2008
Fri, Sep 26, 2008 at 6:44:56 AM | cutting a non-rectangular opening on arc wall? revit 2008
karen618
How to cut a non-rectangular opening on a arc wall?
in Revit 2008
Fri, Sep 26, 2008 at 7:27:10 AM | cutting a non-rectangular opening on arc wall? revit 2008
4 Stars: 203 Votes
Use a "Void" to do that...
Edited on: Fri, Sep 26, 2008 at 8:08:31 AM
Fri, Sep 26, 2008 at 9:01:49 AM | cutting a non-rectangular opening on arc wall? revit 2008
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just my opinion. . . . that is a lame / leading answer with no details or explanation as to 'HOW'. It's also the wrong answer. There is more to that image with the stars than meets the eye. I call this 'confusing the user'.
Instead I would quickly create a new window or door family with no trim or glazing. Much better solution with re-usable content for future projects. Done in about 2 minutes.
See the video link below for a clear explanation of how I would solve this problem.
Fri, Sep 26, 2008 at 9:21:09 PM | cutting a non-rectangular opening on arc wall? revit 2008
karen618
THANKS! IT WORKS! YAY!!!!
Sun, Sep 28, 2008 at 10:15:52 PM | cutting a non-rectangular opening on arc wall? revit 2008
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I knew it would !
I used a 'window' template to make the family in the video. You could do the same with a door template.
It depands on if you want the opening to abide by the catagory of a window or a door once placed in a project.
I struggled with this myself way back when because I did not know you had to hover over and then 'tab' to select the opening perimeter in the family template to edit the outline of the opening with sketch lines. Once you get into 'sketch' mode in the family template you're on your way.
door opening cutting parallel wall
Mon, Sep 15, 2008 at 2:54:10 PM
Non rectangular wall openings
Mon, Jun 23, 2008 at 12:57:05 PM
Simple Question regarding walls
Mon, Jun 4, 2007 at 9:20:23 AM
Arched Opening in a Curved Wall [ 1 2 ]
Mon, May 5, 2014 at 7:16:28 AM
18
Arc Walls with curved top?
Thu, Aug 7, 2008 at 2:04:21 PM
Page generation time: 2.1563
