46 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Sloped Beam Systems in Revit Structure 2009 question
3 Posts No Rating |
Hello all.....New to the Revit world here, so I'm still learning. Anyone's help would be greatly appreciated. I'm running into a couple problems in the project I'm working on in Revit Structure 2009. I'm using a linked model and trying to implement multiple beam systems of bar joists for the roof system. For some reason, I cannot get the beam systems to slope. I can get individual beams to slope. I can get the entire system to change elevations as a group, but cannot get the entire beam systems to slope. I realize that if I had the walls from the central model as well as the bearing points, it should in theory, snap to the bearing points and automatically slope. The problem is that I don't have all of the information from the central model. Is there any way to manually tell the beam system the high points and low points of the slope? Also, I can't seem to get the tags to show up in plan view. I've tried everything I can think of and all I get is a "?" for each member. Any ideas why? Thanks in advance!!!
Sloped Beam Systems Q's |
Mon, Nov 14, 2016 at 11:48:46 AM
Beam systems question |
Tue, Sep 30, 2008 at 2:23:42 PM
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
Non-Planar/Sloped Beam Systems with Elevation Points? |
Thu, Jun 14, 2007 at 12:11:36 AM
Structure Beam System Wishlist |
Thu, Feb 28, 2013 at 4:18:11 PM
Members: | 2056546 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
