21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Revit Patterns?
Ok, we are completing a floor pattern plan using the Settings,Colour Fill and then within this menu selecting floor pattern and chosing a colour and fill. No problem. My question is can you sucessfully put a fill over another fill and see them both? Or do you just need to find another pattern with both and put it in the pat code? Thanks
REVIT 9.0 |
![5 Stars: 3 Votes](/images/stars_5.gif) |
You can't have multiple pattens defined in a single material. you could add a transparent material ontop of something but I'd recommend trying to make the .pat you need.
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
The right way to do it is would be to add it to the .pat file. But if its a pattern you're not going to use again or just need to get it done quickly, all you have to do is use the filled region tool and under the type properties of the region change the background from opaque to transparent. That should do the trick.
Thanks for the quick responses, I ended up spending some time and making the pattern within the pat file. We will be using it more than once.
REVIT 9.0 |
create/ convert hatch patterns (.pat) to revit fill patterns |
Tue, Jun 2, 2015 at 11:29:00 AM
Where do model patterns go? |
Thu, Sep 24, 2015 at 9:37:41 PM
Colors and Patterns in Revit 2013 |
Fri, May 25, 2012 at 7:54:54 PM
Material cut patterns |
Mon, Sep 19, 2016 at 8:56:36 PM
adding patterns to Revit |
Fri, Apr 16, 2004 at 4:12:31 AM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
