69 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> room tag alignment
5 Posts No Rating |
is it possible to rotate room tags other than the "vertical" or "horizontal" options in revit architecture 2009? my drawings are oriented on sheets so that due north is to the left and true north is about 14 degrees off of that. best case scenario would be to be able to align room tags with the orientation of the walls, but i would settle for the vertical alignment if the tags weren't upside-down as a result. thanks
![DOCCODY Avatar](user_avatar/70011.jpg)
6 Posts No Rating |
click room tab, change it to "model", so you can rotate it. But it's too slow, you must do it one by one, if you want change all, you can edit room tab family.
5 Posts No Rating |
i'd like to edit the family so that there's a parameter to rotate all of the room tags at once. is this possible? thanks!
6 Posts No Rating |
Yes, I think You can make a parameter to rotate, but it's a difficult proplem. Open room tag family, rotate all text, make another room tag type. Just a minute ![Smile](/images/smiles/smile.gif)
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
Room Tag Leaders |
Thu, Oct 21, 2021 at 9:45:56 AM
ROOM TAG TAGS ONLY HALF OF THE ROOM |
Wed, May 6, 2015 at 8:58:21 AM
Members: | 2016890 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
