29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Linework on column woes
Thu, Apr 28, 2005 at 4:30:19 PM | Linework on column woes
kfpopeye
Usually when I use the linework tool on walls, etc there are two blue dots that allow me to adjust the extent of the linework. This doesn't seem to happen on columns however. I have two columns that are hidden in elevation by a rail. When I try to adjust the linework the line shows right through the rail with no blue dots to let me adjust. Anyone know why this is?
Life is one of those things that people find hard to avoid. - Rowan Atkinson
Thu, Apr 28, 2005 at 10:23:47 PM | RE: Linework on column woes
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I believe this is the same with all loaded families (non system families). would suggest just using detail lines and locking them to the column...
Fri, Apr 29, 2005 at 12:40:35 PM | RE: Linework on column woes
kfpopeye
It seems to work for square columns. Just round columns don't work properly. See attached sample file and try it.
Can you save linework?
Tue, Aug 12, 2008 at 7:37:07 PM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Improving Linework in Sections & Elevations
Sun, Mar 30, 2008 at 12:30:48 AM
Page generation time: 14.7585
