83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Architect is using ArchiCAD Structural Consultant using Revit?
Mon, Sep 22, 2008 at 1:21:43 PM | Architect is using ArchiCAD Structural Consultant using Revit?
jf20spiker
I work for a large Structural Consulting firm.  We are working on a new project where the Architect will be using ArchiCAD.  Our office is well trained in Revit as we have been using it since RST 2.  We have some concerns (mainly because we have  very little experience with ArchiCAD) about the interoperability of these two programs.
 The architect is also voicing some concerns over the ability to do clash detection using two different platforms.
1. Does anyone have any experience with using these two programs together?
2. Does ArchiCAD export a file type that can be easily imported both into Revit for our use?
3. Does ArchiCAD import a file type that Revit can export?
4. If yes, can you do clash detection inside ArchiCAD directly? (If not can you import both into Navisworks?)
Thanks
Joseph F
BIM Coordinator
Mon, Sep 22, 2008 at 1:53:37 PM | Architect is using ArchiCAD Structural Consultant using Revit?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
IFC format
Mon, Sep 22, 2008 at 2:10:03 PM | Architect is using ArchiCAD Structural Consultant using Revit?
coreed
coreed Avatar
4 Stars: 16 Votes
other than IFC, both programs can read and write dwg. i don't know if that is something you can use for your intended purposes.
FYI, Archicad is starting a new campaign with prupose of grabbing a larger share of the U.S. market. So this may be a very commom situation in the near future.
Edited on: Mon, Sep 22, 2008 at 2:14:28 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Sep 22, 2008 at 2:43:50 PM | Architect is using ArchiCAD Structural Consultant using Revit?
jf20spiker
I've heard that exporting to IFC from Revit will cause problems where you have an outside family that you have created repeating in your project.  Apparently these families will not be included in the IFC export.  Does anyone have any information on this?
Thanks again!
Joseph F
BIM Coordinator
Thu, Nov 27, 2008 at 11:23:30 PM | Architect is using ArchiCAD Structural Consultant using Revit?
sugna
Quoted from ArchiCAD-Talk:  http://archicad-talk.graphisoft.com/viewtopic.php?t=26267&highlight=
 Paulinahtoo said:
Here is my experience. We work in AC12 and our consultants in Revit, Revit MEP and Revit Structure. Our exchange with Revit Structure via IFC has been perfect. With MEP we get everything across clearly but we have had trouble exporting/importing two elements : dynamic grids and dynamic annotations. As far as interface and accessibility goes, AC has a much better interface, explanation and openess to allow you to learn IFC and working with it.. Revit doesnt have such an extensive access mostly because (and i think this is my bias) Autodesk has been too arrogant in thinking everyone will use its programs to actually put time and effort into developing a useable interface for this open source language. Either way through trial and error we have been able to utilize IFC and exchange and coordinate 3d structure and mep models relatively easily. Now if I can learn/figure out how to show dynamic text and grids... Id be really happy
Revit 2014 Consultant Model Issuance
Fri, Jun 6, 2014 at 10:40:43 AM
Collaborating with structural consultant - RAC 2008
Tue, Sep 18, 2007 at 4:41:27 PM
Origin change by Architect??
Mon, Mar 11, 2013 at 8:58:40 AM
Revit vs. Archicad [ 1 2 ]
Fri, Sep 28, 2007 at 11:57:54 PM
15
Copying Architect's columns into structural
Tue, Mar 8, 2011 at 4:08:45 PM
Page generation time: 2.6398
