145 Users Online (144 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Link suite tags to area plan tags?
Sat, Sep 20, 2008 at 4:00:34 PM | Link suite tags to area plan tags?
markuspirker
I defined the areas i want in my area plans but can't get the info into my floor plans. Is there a tag that creates the link? Can i have custom area boundaries in my floor plans? All I want is to display the total area of a suite. The default room bounding options do not work for me becaues they cannot distuingish between shared partion walls and exterior walls.
Thanks
Sun, Sep 21, 2008 at 10:38:47 AM | Link suite tags to area plan tags?
Areas and rooms are different entities so there is no link.
Room boundary lines will work for you - just turn off room bounding for your walls and use the room boundry lines.
Sun, Sep 21, 2008 at 1:49:47 PM | Link suite tags to area plan tags?
markuspirker
Well, that is my point.
The default room bounding options do not work because they do not distuingish between exterior walls which are measured to the outside face and shared partition walls between suites which are measured to the center line of the wall. I can only choose to go to the outside face or center line or inside face for all walls but not for each individual room bounding wall.
Is there a way to work around that or do I have to define this in the area plan and then manually type it in at my floorplans, which is a bit tedious.
cheers
Mon, Sep 22, 2008 at 7:18:13 AM | Link suite tags to area plan tags?
Sorry - but I don't think you understand.
You can draw area lines anywhere.  You don't need to use the automatic lines.  If you are doing area plans, look at the area schemes options - gross vs rentable.
Ditto for room boundry lines! You can draw them anywhere.  Will they ever become walls dividing rooms?  NO but you can point to them when you are adding walls and you can pre-set if you want the wall centered on the line - the core edge on the line or the inside/outside face on the line.
Edited on: Mon, Sep 22, 2008 at 7:45:35 AM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:39 AM
incompatible area tags
Sat, Jan 14, 2006 at 1:57:47 AM
tags tags tags
Tue, Mar 20, 2012 at 12:10:24 PM
Area Tags
Thu, Jul 29, 2010 at 12:43:27 PM
Area plan not printing walls and doors below colors
Sat, Mar 14, 2015 at 1:26:37 PM
Page generation time: 1.7304
