55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Double pitched roof???
10 Posts No Rating |
How would I go about making a simple double pitched roof? ie: 4/12 pitch for the first 6' then to an 8/12 pitch to the ridge.
Use two roofs, then join them...
Nice!!! Thanks
1 Posts No Rating |
oh yeah, how do you join them, with glue? I have a metal roof that is 25° and then 15° over a verandah all the way around. Can revit do this with the section showing a proper join so I dont have to draft it up properly in section. Might as well use AutoCAD or ArchiCAD!
The software is not the culprit. The software has the tools. Single Roof in Revit in less than 5 minutes:
Planta1 Revit Online Consulting | info@planta1.com |
another double pitch roof question! |
Thu, Jun 14, 2007 at 10:42:50 AM
a pitched hip roof with an arched dormer window and standing metal seam finish |
Wed, Nov 13, 2019 at 5:31:44 AM
Double Pitched Underslung Joists |
Tue, Apr 29, 2014 at 12:47:09 PM
Family Needed - Top Chord Offsed Double Pitched Underslung Steel Joists |
Tue, May 18, 2010 at 11:40:49 AM
double pitched top chord joist seats |
Tue, Feb 15, 2011 at 3:37:51 PM
Members: | 2042512 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
