50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2009 - unwanted lines on walls from window and door openings
Fri, Sep 19, 2008 at 7:43:19 AM | Revit 2009 - unwanted lines on walls from window and door openings
GWak
Demolishing windows or doors is leaving an outline of the wall infill in a black line.  The same happens if I place a family in a proposed phase wall - the lines appear in the existing phase.  can anyone help me with this?  Please?
Anyone tried getting on the chat room?  I just got a load of abuse!!  Not very welcoming.
Thanks for any help in advance.
Fri, Sep 19, 2008 at 8:11:06 AM | Revit 2009 - unwanted lines on walls from window and door openings
3.5 Stars: 396 Votes
You need to use your help to better understand how to control how phases are displayed.
If you do not want the outline of the infill to show up in elevation, use your linework tool and change the outline to invisible line.
Fri, Sep 19, 2008 at 8:46:22 AM | Revit 2009 - unwanted lines on walls from window and door openings
GWak
Thanks for the advice but this isnt the problem.  The same thing happens with other door and window families that I havent created.  I have tried making the same wall and window etc in another file and it doesnt happen.  It is just this file it happens on so I am assuming that there is something in that file which it doesnt like.  Any other thoughts?
Tue, Jan 6, 2009 at 10:01:19 AM | Revit 2009 - unwanted lines on walls from window and door openings
benbens
Check your wall and infill properties.  They need to have the same structural usage (bearing, non-bearing, etc.).
Problems with visibility of Header and door openings
Fri, Jul 26, 2013 at 11:05:23 AM
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:28 PM
When use ''door opening'' dasced lines present only at 1:50 but not at 1:400 f.e
Fri, Jun 11, 2021 at 7:44:53 AM
unwanted lines & wanted lines
Sat, Feb 26, 2011 at 12:50:13 PM
radiused corners at door and window openings?
Mon, Oct 25, 2010 at 6:08:57 PM
Page generation time: 7.8588
