48 Users Online (47 Members):
Forums >> Revit Structure >> Technical Support >> Title blocks
22 Posts No Rating |
Hi guys, I'm in the process of producing title block templates and have found an issue regarding the date the drawing was produced. I'm based in England and we write the date as 19.09.08, revit automatically inputs the date as 09.19.08. Is there any way I can change this so that all drawings show the date the English way rather than the American when the template is used? I know I can change it manually but that sort of defeats the idea of having labels. Cheers Adam
![psymon Avatar](user_avatar/9799.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
I am not sure where the setting is but ours display that way ( we are in Australia). Does your PC show the correct date/time configuration in explorer say? If not (if you use windows) you need to change your system settings.
Delete or Purge out Title Blocks? |
Wed, Nov 26, 2008 at 5:06:00 PM
Customize new Title Blocks |
Mon, Sep 21, 2009 at 2:55:19 PM
Sheets Title Blocks |
Mon, Jul 6, 2015 at 2:30:16 PM
Title blocks |
Mon, May 11, 2009 at 2:53:44 PM
creating custom title blocks |
Tue, May 22, 2007 at 2:29:40 PM
Members: | 2022352 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
