Forums >> Revit Building >> Technical Support >> DWG graphics
10 Posts No Rating |
My civil and landscape dwgs are not representing correctly in my revit site plan. Graphics are way off and sometimes being represented by random, small, solid black triangles. Any suggestions?
Can you post an image?
And what version of Revit do you use?
Thanks for the reply. I'm using Revit and CAD 2008. See attached for revit and CAD representations of the same site info. You'll notice that the CAD linework that defines the concrete score marks doesn't represent in revit but for the triangles lining the edge of the pathway. You'll also notice the CAD linework for the crosswalk near the bottom center of the revit image is almost there but the linework does not clean-up correctly, etc. Thanks for your help.....
Edited on: Fri, Sep 19, 2008 at 12:06:29 PM
Any help here would be appreciated. I'm struggling here.
I think that your problem may have to do with AutoCAD blocks. Your cad drawing may be a bound xref which may be a block or the drawing itself may be a block. If this is the case, explode your drawing and reinsert it into Revit and it should read correctly. Post again if this does not solve the problem.
Revit conflict with AutoCAD dwg - element graphics display issues |
Fri, Feb 14, 2014 at 10:05:52 AM
11
dwg in Revit Link not visable |
Thu, Oct 4, 2012 at 12:43:41 PM
DWG import |
Sat, Mar 7, 2009 at 5:56:44 AM
exporting to dwg |
Wed, Aug 18, 2010 at 5:10:22 AM
imported dwg lineweights, linetypes |
Fri, Aug 10, 2007 at 9:22:54 AM
Members: | 2115407 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
