108 Users Online (106 Members):
Forums >> Revit Building >> Technical Support >> wall display properites
160 Posts No Rating |
I have bearing walls and non-bearing. I created the brg wall by duplicating the non brg. When I go to edit assembly and change the cut pattern to represent brg, it also changes the non brg. wall. seems like I should know this, just not getting it. How can I create a wall that's entirely independant from the others when changing the display properties? RAC2008
Did you duplicate (first) the wall and give another name before you change the properties of the wall?
edit duplicate rename ok and ok to cancel out of properties box. I can get the walls in the "detail level: course" to show up differently when I change the detail level to course. But when I change the cut pattern in the edit assembly materials dialogue box it changes all of the walls to the same cut pattern.
Hi, i gonna put a video, wait a few moments... See the video and give me a feeback: http://screencast.com/t/QdYDXqHGqIO
Edited on: Thu, Sep 18, 2008 at 2:29:13 PM
![4 Stars: 19 Votes](/images/stars_4.gif) |
You need to duplicate the material or give it a new one - then you can change them independantly.
Wall Join Display |
Thu, Oct 14, 2010 at 12:52:50 PM
Wall Display in Plan |
Wed, Jan 13, 2010 at 12:30:59 PM
Reporting parameter from curtain wall door in Curtain Wall Schedule |
Mon, Dec 19, 2022 at 5:44:58 AM
11
Wall display issue |
Tue, Jul 6, 2010 at 5:00:14 PM
How do you control the display of wall layers in the Roof Plan? |
Fri, Jul 20, 2012 at 10:51:46 AM
Members: | 2017084 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
