66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Section Line in Extends Beyond Plan (2009)
8 Posts No Rating |
Is there a way to edit the extents of section lines in plan in 2d without affecting the view range of the section view itself? We have a whole building section line that should show on a partial plan, but the section line is extending the full length of the building even though the plan ends. This seem to be possible, but when I try to drag the section line, I can't click change the end location.
Hi, i don't know if this is exactly what do you want but you can pick in the 2D section line and drag the "Blue dots" at the end of the section line and in this way you don't affect the view in section, see the image attached.
Edited on: Sun, Sep 21, 2008 at 12:40:06 PM
Section line disappears from plan when section view is placed on same sheet |
Thu, Sep 4, 2014 at 7:46:20 AM
Breaking a Jogged Section Line - Hiding Central Portion |
Thu, Aug 1, 2013 at 5:52:35 PM
Leader Line Line weights |
Sat, Feb 7, 2009 at 10:47:57 AM
Section tag missing on plan but section still exists |
Tue, Nov 22, 2016 at 2:58:15 PM
plan/section segmented cut line |
Mon, Mar 7, 2005 at 7:12:24 PM
Members: | 2016934 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
