67 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Revolve Components in elevation
7 Posts No Rating |
Hello, Revit Ver 2009. I am modeling a piece of equipment that can be described as having a similar function to that of a flagpole base that allows the pole to be rotated on a pivot about 3' high so the pole can be lowered for maintenance. There is a counterweight below the pivot to reduce the force needed to rotate the pole  in elevation view) from horizontal to vertical. I started to model the unit and found that I could not rotate the rotatable component(s) about the axis in elevation view. Is there a way to build a family or what I have is nested families so that it can be shown rotated in elevation view in relation to the base component of the model? With this particular equipment, it is important to show it both vertical and rotated to a horizontal position. Thank You (again), Petey
Probably several options here. You could have two families that are in the same place but different phases - one up and one down then control the phase in VG. You could have both families in the same place and just hide in view the one you don't want. (With symbollic lines only in elevation.) Only one family would exist in plan.... You could build the family with two different symbollic linetypes and then turn on/off the linetypes in VG. I'm sure there are other ways .....
7 Posts No Rating |
Although I have been using Revit for 2+ years and have over 1/2 million S.F. of design work completed to date, I still (and realize that I will) frequently run up against a Petey-Revit problem. After searching, almost always the Revit part is not the problem, and the solution was so simple that if I had posted, I would have been embarassed that I asked such a question. This may be a question that no one understands because it is so simple. I wish I could get over the hump and know at the soul of Revit. This question will show that I am not there--yet. So I am trying to rotate a component (family) (that I created using a generic family template) relative to the entire model, in elevation view. I can not do this? I have to create another family from scratch at a rotated angle to show the model with that component rotated to various angles in relation to the base? This gotta be simple. BTW I don't know why that cryin icon showed up on my post. It's nothin to cry about. Scream and yell sometimes.
Edited on: Tue, Sep 16, 2008 at 10:46:06 AM
Actually, if your family is built so that all you have to do is rotate it, then do that ... you may have to uncheck tthe property "always vertical" in the family if you can't seem to rotate it.
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Does this family need to be able to attain any degree of rotation betwee 90 and 0 from horizontal or can it just be vertical in one instance and horizontal in another instance?
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
Give this a shot. There is an instance parameter called vertical. Play with it, I dare you! You can use this as a starter. I've uploaded it to the library.
using revolve tool to shape top of walls 'Revit 2012' |
Wed, Feb 20, 2013 at 2:47:55 PM
How to Lock a Radius Revolve to Reference Plans in Plan and Elevation? |
Sun, Jul 17, 2011 at 1:52:29 PM
Revolve along a curved axis? |
Tue, Apr 1, 2008 at 3:40:01 PM
Faceting a Revolve instead of Smooth Result [ 1 2 ] |
Wed, Jun 10, 2009 at 9:17:01 PM
15
Revolve Axis |
Wed, Mar 29, 2006 at 2:46:10 AM
Members: | 2016947 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
