53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2009 error message from linking
Mon, Sep 15, 2008 at 11:52:31 AM | Revit 2009 error message from linking
REEE
Linked file "b" central.rvt cannot be saved because it has changes in more than just shared coordinates and therefore can invalidate local files by you.
One of my coworkers mistakenly linked revit link "b" central into revit link "A" central. Now the above error happens.
I am going to try removing from central A. Kicking everyone out of the project for alittle bit, saving a new local and linking from local saving back to central and then... having everyone replace their locals with the updated file.
Sound feasable?
Also I need to link "a" into "b"
Basically a core and shell issued now with interior buildout later.
I just started in Revit for the 1st time Last week. This is pretty exciting.
Sat, Sep 20, 2008 at 9:45:00 AM | Revit 2009 error message from linking
kesflower
3.5 Stars: 11 Votes
Sounds workable to me.  I LOVE it when people rearrange the central file.  Kicking everyone out and redoing the central is the only way to fix the problem.  We've found that a little instructions sheet in the central file (Usually on a titleblock called "READ ME FIRST"Winking as to how to save, link, and generally use the workset helps with keeping the central file clean.
Best of luck.
Ruth Rau
Main Street Architecture, P.C.
Mon, Sep 22, 2008 at 12:39:48 AM | Revit 2009 error message from linking
mgr2820
2 Stars: 2 Votes
This error occurs because of cad files loaded into one, or both of your revit files. The cad files block revit from saving through the link. Are you using cad as a reference in one of the files...updating the cad link as you work? This is the problem. It is changes to these cad files that Revit is referencing as "changes to more than shared coordinates". Remove the cad files and everything should be fine.
Check the AUGI forum for more detailed info on this problem.
Mon, Sep 22, 2008 at 7:30:48 AM | Revit 2009 error message from linking
REEE
THANKS FOR THE REPLIES!!!!
WE DO HAVE CAD LINKS IN BOTH CENTRALS
THANKFULLY THEY WILL BE REMOVED SOON. WE WERE USING THEM TO TRACE/GENERATE WALLS AND SUCH
HAPPY AUTUMN
Mon, Sep 22, 2008 at 9:58:17 PM | Revit 2009 error message from linking
mgr2820
2 Stars: 2 Votes
If you need to have cad references in your file - import it into a detail component family, then load it into the project.
revit 2009 error message
Fri, Sep 3, 2010 at 8:23:07 AM
3D window error message-Revit 2009
Fri, Sep 15, 2017 at 2:51:33 AM
error message prevents upgrade to revit 2009**
Wed, Jul 23, 2008 at 9:04:28 AM
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:48 PM
ERROR MESSAGE: STAIRS - rises not intersecting boundries?
Tue, Aug 19, 2008 at 9:12:33 AM
Page generation time: 1.8046
