46 Users Online (44 Members):
Forums >> Revit Building >> Tips & Tricks >> existing walls
19 Posts No Rating |
I am doing a small renovation and I would like the existing walls to show without hatching/patterning. Does anyone know a good way to make that happen? I can't seem to find it.
Thanks,
Steve
admin
![hjacobs Avatar](user_avatar/2.jpg)
![3.5 Stars: 16 Votes](/images/stars_3.5.gif) |
go to settings/materials and find the material called phase-exist. Edit the cut properties to your desires. For instance, we show our existing walls as solid black. We give the phase-exist material that cut pattern. You could give it a solid white pattern
Hiroshi Jacobs
The Catholic University of America |
thanks, that worked well for section, but it doesn't seem to be working for the plans. Is there a way to make it work for plan as well?
steve
admin
that should work for plans just fine too...
Hiroshi Jacobs
![jjlangh Avatar](user_avatar/37974.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
I sort of have the same issue: i am working on an addition and have existing walls and floor that i want to show grayed-out in plan and section, but the client also would like to see a 3D image of the existing building with the addition. In the 3D image i don't want to have the existing show up as gray and the addition with the correct material. Is there a way to surface apply a material in the element properties structure tab so that it just shows up in the 3D?
Nevermind - i just got it figured out.
Walls set as existing not showing up in existing phase settings. |
Sat, Aug 4, 2012 at 11:21:58 AM
hatch existing walls black (phasing) |
Fri, Jun 2, 2006 at 7:35:19 AM
Rendering existing storefront walls |
Thu, Oct 20, 2005 at 4:43:44 PM
existing walls |
Wed, Jul 3, 2013 at 10:19:13 PM
Rendering- existing walls and Windows |
Mon, Sep 26, 2011 at 3:41:09 PM
Members: | 2022237 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
