68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> ArchiCAD Elements Converted or Imported Into Revit Family Templates
Thu, Sep 11, 2008 at 11:28:17 PM | ArchiCAD Elements Converted or Imported Into Revit Family Templates
Revidiot
Can it be done?
Specifically casework. My company aquired another firm that used Archicad and they have a ton of S&T casework. Can these elements be imported into a family template? Or can they be converted?
Thanks in advance!
Ben
Fri, Sep 19, 2008 at 6:11:24 AM | ArchiCAD Elements Converted or Imported Into Revit Family Templates
robinballew
robinballew Avatar
3 Stars: 4 Votes
You will have to export from ArchiCad to some other format. I don't know ArchiCad but you could try DWG, DGN, SKP. You can then import the file into a Revit Family.
BallewDesigns.com
Fri, Sep 19, 2008 at 7:56:30 AM | ArchiCAD Elements Converted or Imported Into Revit Family Templates
Revidiot
Thank you.
I will give that a try.
Great avatar by the way.
Thu, Nov 27, 2008 at 11:50:46 PM | ArchiCAD Elements Converted or Imported Into Revit Family Templates
sugna
how about 3ds?
Fri, Nov 28, 2008 at 4:45:01 AM | ArchiCAD Elements Converted or Imported Into Revit Family Templates
4 Stars: 202 Votes
It's the same, you must export in DWG.... it's like the same in Rhino, Sketchup and so one....
Architect is using ArchiCAD Structural Consultant using Revit?
Thu, Nov 27, 2008 at 11:23:31 PM
Revit vs. Archicad [ 1 2 ]
Fri, Sep 28, 2007 at 11:57:55 PM
15
Imported family is exploded in project
Fri, Aug 12, 2011 at 7:31:03 AM
recognize solid imported objects as mass elements...
Tue, Jan 20, 2009 at 10:26:34 AM
REVIT 2009 VS ARCHICAD 12 [ 1 2 3 ]
Wed, Aug 22, 2012 at 10:03:50 PM
33
Page generation time: 2.4862
