61 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> Family Help Plz - Rotation Problem
21 Posts No Rating |
Hi all, some help with this simple annotation family would be great - its starting to drive me insane. What i have is a north symbol that i wont to use and all it needs to do is rotate around the centre - its works fine untill you change the degrees to 180 and try to rotate again it jumps from the centre point into nomans land. I think there is a simple solution but for the life of me i cant work it out i have even trird pinning it with no evail. thanks for any help
----------------------------------- Brett |
![timbo89 Avatar](user_avatar/48408.jpg)
![4 Stars: 5 Votes](/images/stars_4.gif) |
I just loaded your family into a project and when I changed the degrees everything worked fine. All the angles worked and it didn't end up in no mans land when its actually in a project. You should try loaading it into a project and seeing how it goes there, because it was fine for me =)
- Core 2 Duo E8400 3ghz
- 756mb Nvidia 9600GSO 256bit
- 6gb Kingston RAM 800mz DDR2
- Windows XP Service Pack 3 32-bit
yes your right timbo thanks i didnt even think to load it into project just testing it in family. Well i know that for next time
Strange problem !!! hlp plz |
Thu, May 29, 2008 at 4:14:42 PM
13
Having Problem rotating family after it is loaded in the project...(see pic) |
Thu, May 22, 2008 at 2:49:26 AM
Family type control for rotation? |
Fri, Mar 14, 2008 at 6:15:14 AM
View Rotation on a Sheet |
Tue, Feb 14, 2012 at 1:32:37 AM
what happened to dims |
Sun, Nov 1, 2009 at 5:54:11 AM
Members: | 2022349 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
