Forums >> Revit Building >> Technical Support >> Imaginary Surfaces
24 Posts No Rating |
I work for a Airport Developer. Everything we build has to fit under these imaginary surfaces for obivous reasons. What I'd like to do is build these imaginary surfaces in Revit so i can build my hangars and office buildings then place them "hopefully" under this imaginary surface. Here's a pdf I found online that can explain it a little better: http://www.dot.ca.gov/hq/planning/aeronaut/documents/PT77_Ism%20Layout1%20(1).pdf OK my question is how do I build a surface... I'd like to be able to see through this surface like this image shows: http://www.openairport.org/images/oa_ge_outview.jpg I was trying to use a roof command although it would a huge roof :-) What would you use to create this "imaginary surface in Revit??? This surface would start at a surface point and have a 7:1 Slope. I'm also not sure how to create that slope in Revit either. I'm using Revit Architecture 2009 and I just finished the essentials class on 9/10/2008 Thanks for any help at all!
![4 Stars: 5 Votes](/images/stars_4.gif) |
You could use transparent walls and make them huge. Or, you could use massing
Is there a material out there that would be see thru? I'd like to make these a red tint...
![coreed Avatar](user_avatar/14568.jpg)
"Is there a material out there that would be see thru? I'd like to make these a red tint..." you can use any color, just adjust the opacity to make it transparent.
Create a mass on that and give the material, you can choose "Glass Red" , go to materials>glass, you will see the Red Glass....
I'm not sure why I'm having such a difficult time with the massing. I can only extrude this from floor plan 1 to the desired height. but in reality I should be drawing a triangle in the north elevation and extruding it but I haven't been able to do this. I thought I could extrude and then rotate the entire mass on its side. Any suggestions at all?
Hi, see the video: http://screencast.com/t/4tZDHxjo07
Typhoon, Thank you so much for the help!! I will try it out as soon as I can! Thanks again!!!
New Guy... |
Thu, Sep 11, 2008 at 6:33:25 PM
Angular surfaces |
Fri, Oct 16, 2009 at 2:23:30 PM
Turning floor surfaces off for individual floor elements? |
Thu, Jun 29, 2006 at 1:31:20 AM
How to take quantities from painted surfaces? |
Tue, Oct 10, 2017 at 1:00:43 AM
import dwg surfaces into Revit |
Fri, Mar 6, 2015 at 1:56:09 PM
