84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009 - Grid and Level lines obscure model elements
12 Posts No Rating |
I need to show the grid and level lines on my sections and building elevations, but in several cases they obscure important parts of the drawing. If I were working in AutoCad (glad I'm not!) I would simply send them to the back. What can I do in Revit to do the same? Thanks, Julie
Hi, in element properties - edit, there is a selection that allows you to change the color of your segments. You can use a light gray to lighten the segments HTH
I like to go into the type properties of my grid lines and turn off the center segment, plate lines you can select and make sure they are set to 2D then stretch them wherever you want and it wont effect the model.
You also can pick in the element(s) you want and right-buttom go to "Override Graphics in View" and you can choose "By Element" and you can change the parameters "Visible, Halftone and Transparent" to that/those objects...
Obscure Wall Patterns behind Family drawn with Symbolic Lines? |
Thu, Feb 27, 2014 at 7:24:42 AM
Grid line for Revit Architecture 2009 |
Wed, Mar 24, 2010 at 8:21:53 PM
Grid lines/florrlines all messed up. curved logo generation for bldg elevations |
Mon, Oct 22, 2007 at 5:49:31 PM
grid lines extend beyond detail |
Mon, Jul 20, 2009 at 2:06:00 PM
grid lines question revit 2009 |
Tue, Nov 25, 2008 at 12:03:27 PM
Members: | 2017008 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
