121 Users Online (120 Members):
Forums >> Revit Structure >> Tips & Tricks >> Using a Steel Angle as a Hanger or Column
20 Posts No Rating |
I'm using Revit 2008. I'm new to Revit. In the project that I'm modeling, I have a need for an angle to be used as a hanger or a column. I've tried adjusted the element properties of the angle to allow it to be used horizontally, then have reloaded into the project. Now, I'm trying to develop a new family for the angle, but have run into a brick wall. Any suggestions?
Take the profile and use it to make a new column family. You should be able to use the steel angle from the structural elements as a hanger.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG |
Also copy the txt file associated to angle and name it the same as the new column family you made and you have all the sizes too -I had to make WT columns for a project and did it the same way-it works-I think I uploaded the WT col. family here-I left the extra parameter in for the other flange (and in the text file)-because I was lazy -no need to over exert myself-hahahaha.
Another option: Edit the Angle Family Go to Settings -> Family Category and Parameters -> [Uncheck the 'Always Vertical' option] Re-load into project OR Save As new family and copy/modify text file. In project, you can now rotate (after clicking disjoin on the editing bar) the beam 90° You can also stretch the vertical member up and down, as opposed to defining it's lenght by reference levels.
Angle Column Family |
Fri, Jan 16, 2009 at 5:09:36 PM
Lineweight of steel column in coarse view |
Fri, Jan 7, 2011 at 6:25:48 PM
Complex Steel Columns |
Tue, Jul 1, 2008 at 10:21:51 AM
Angle parameter for column? |
Thu, Jan 23, 2014 at 5:38:28 PM
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
Members: | 2042293 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
