42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Egress Block, Tag, and schedule - Revit 2008 or 2009
Thu, Sep 11, 2008 at 11:57:41 AM | Egress Block, Tag, and schedule - Revit 2008 or 2009
Jmarchese
We have created an egress symbol which allows the end user to input the Egress Width and Factor and in turn will calculate the Egress Capacity. We also have parameters for the end user to edit the Exit Number and Exit Type (See BMP 1). We have created a tag to attach to the symbol which will read these parameters. Finally, we've created a schedule for all of this information. We are having an issue where the schedule is placing one line above all the information(see BMP2) which, when I click "Show", ends up highlighting the doors. My question is: what parameter could possibly be putting the doors in my schedule? For now, manual entry of this information is fine, but if anyone could possibly answer these "wishlist" items, that'd be great:How can I get the tag to "host" to a door or stair and read the Element property automatically?Can I get the tag to read the "Width" parameters automatically?Thanks for all of your help!Jim
Fri, Sep 12, 2008 at 9:59:29 AM | Egress Block, Tag, and schedule - Revit 2008 or 2009
Jmarchese
Anyone have any ideas about the schedule portion of my question?
Thu, Oct 23, 2008 at 12:48:14 AM | Egress Block, Tag, and schedule - Revit 2008 or 2009
mattmols
I was just creating tags to display egress requirements for doors and stairs.  I was getting very frustrated until I realized I needed to create shared parameters from the project parameters window.  I also edited my doors to have some of the same parameters.  Without going into depth with text, download my attachment and see if this answers your question.
Edited on: Thu, Oct 23, 2008 at 12:53:11 AM
xxx
Fri, Mar 2, 2012 at 10:22:19 AM | Egress Block, Tag, and schedule - Revit 2008 or 2009
Archispaz
Mattmols,
Did you ever figure out how to make this work with a stair width?
Egress Door Tag
Tue, Mar 12, 2013 at 3:29:33 PM
Revit 2013 - Egress Path as Model Line
Fri, Jan 24, 2014 at 7:22:58 AM
Tag Suite and Maintain Rooms
Mon, Oct 28, 2013 at 8:58:39 AM
Title Block link from Schedule?
Thu, Sep 13, 2007 at 4:12:01 AM
tag an imported dwg title block
Thu, May 12, 2011 at 12:34:14 PM
Page generation time: 2.4425
