36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> cannot get rid of lines join cavity in wall
Thu, Sep 11, 2008 at 8:12:34 AM | cannot get rid of lines join cavity in wall
frenchie11
when creating a 280 cavity wall ( 115mm structures x 2 with 50 mm Air Barrier) and join it to a 115mm brick wall with a window or door, line hit the cavity of the 280mm wall from the 115mm wall. See picture attached.
 Please could anyone help in fixing this problem. the only way i know how is by using filled regions to cover the lines
thanks
Thu, Sep 11, 2008 at 9:22:28 AM | cannot get rid of lines join cavity in wall
Dafpfy
3.5 Stars: 11 Votes
try using join geometrie .
or try using the linework tool ( located next to the match type tool and tape measure icon) set to invisible line.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, Sep 11, 2008 at 9:35:22 AM | cannot get rid of lines join cavity in wall
4 Stars: 203 Votes
Hi, i'm sure you did try with "edit wall jons" but in that 280mm wall, did you change the "core"? it's only in the Interior 115mm or you include the Air Barrier?
Thu, Sep 11, 2008 at 9:37:23 AM | cannot get rid of lines join cavity in wall
frenchie11
none of those options work. i can get those lines to go away, if i edit the wall and move the core boundaries out of the structures, but then the cavity around the door changes. as shown in the jpg attached called untitled1.
thanks for the help so far
Fri, Sep 12, 2008 at 8:31:29 AM | cannot get rid of lines join cavity in wall
Tugalo
Normally when this happens to me I can just move the outside wall out then back to the original location and the wall fixes itself.  If that does not work it it probably something in the structure properties box that has to deal with how the walls are wrapped.  I normally only let the outside wall wrap...
Cavity Wall - Cavity Not Filled
Mon, Jun 16, 2008 at 5:42:38 AM
Joining Cavity wall with separating wall
Mon, Jul 14, 2014 at 9:12:31 PM
Cavity Wall Around Bay Not Showing Correct Detail
Sun, Jan 17, 2010 at 3:50:13 PM
Getting rid of material lines within walls
Tue, May 10, 2011 at 1:29:53 PM
Joining different Cavity walls
Mon, Jan 5, 2015 at 12:26:43 PM
Page generation time: 1.1405
