63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Can i get Framing to amend to Warped slab.
Wed, Sep 10, 2008 at 12:29:56 PM | Can i get Framing to amend to Warped slab.
DaveF
Hi. I’m using RS '08. Please see attached file. I drew a frame with level beams & drew a slab. I then warped the slab by placing a point & lowering it 500. As you can see the frame remained horizontal. Is it possible to get the frame to move with the slab or have I messed up in the creation of this model? If not, what would be the easiest way to amend the beams? Please be aware this is a simple example, my project is a bit more complicated. Hope you can help. Cheers Dave F.
Fri, Sep 12, 2008 at 1:00:09 PM | Can i get Framing to amend to Warped slab.
cganiere
cganiere Avatar
Create a reference plane and align and lock it to the slab and the beam. Any movement of the raference plans should force the two locked elements to follow.
Edited on: Fri, Sep 12, 2008 at 1:01:36 PM
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Mon, Sep 15, 2008 at 3:27:30 AM | Can i get Framing to amend to Warped slab.
DaveF
Hi
For a warped slab that falls in 2 directions as per my example?
Sorry, i tried your idea but couldn't get it to work. Could you poste an example?
Mon, Sep 15, 2008 at 1:10:53 PM | Can i get Framing to amend to Warped slab.
cganiere
cganiere Avatar
Using a reference plane, it will only conform to a single slope.
If you have it warped in two directions the only solution is to create a custom element.
Skype: ArchitectCRG
Warped Plane Roof
Fri, Jan 20, 2012 at 2:08:45 PM
How to model a warped roof?
Sun, Aug 14, 2011 at 7:24:19 AM
Floor framing not showing up
Fri, Jan 22, 2010 at 1:47:18 PM
Sloped railing on a Floor
Fri, Jul 2, 2010 at 11:32:11 AM
warped plane roof
Mon, Oct 23, 2006 at 7:26:30 PM
Page generation time: 0.2897
